rob63mess
Hey Guys,
The 30 roadster is running great. Its been 90 degrees or better here in central Ohio and I've been putting plenty of miles on the car with no overheating or problems of any kind. However, when accelerating, the motor is a little chattery. Doesn't do it at Idle. Not a knock and as soon as I get to cruising speed and back off the accelerator its as quiet as a kitten. I replaced the pistons last summer and checked all of the babbit and clearances on the mains and the rods. I was thinking maybe a small exhaust leak or something along those lines. I've tried to think of the obvious like making sure the distributor shaft it well lubed. Again, I cant tell you how well the car is running, but I would like to here any suggestions you guys have. As always, i'm indebted to all of you for the help you provide.
Rob
Rob
