Clutch fingers are out of adjustment. All else is symptoms of improper finger adjustment.
True, but they can be bent to match if done carefully. Hang a box end wrench around the finger and use another wrench as a cheater bar and you can bend them slightly. That is usually all they need is slight bend.
============================================================True, but they can be bent to match if done carefully. Hang a box end wrench around the finger and use another wrench as a cheater bar and you can bend them slightly. That is usually all they need is slight bend.
