I really can't tell on that video do you think the knock is gone
About the fuel line that is a carb I borrowed. My carb has the side sediment bowl and it will be going back on. It fits the current fuel line.
Sorry but being in a rush before work while doing my final timing checks I left the rotor button out. That's why she wouldn't fire. But she is back together and running. You be the judge of whether the new gears fixed the knock.
Before
https://youtu.be/3R3eLKlvVmU
After
https://youtu.be/C-MMJRXug8E
Sent from my SM-N950U using Tapatalk
Probably worn bearings/pistons. Retarding the timing lowers combustion pressure thus making rattles quiet down. This was an old used car dealer trick to sell a clunker. The engine would sound good until the new owner had it tuned up. Setting the timing to proper specs would bring on the knocking.I did not check clearances. However today I noticed while running around 40 mph I could bring the timing lever up about a quarter of the way and the motor would quite down. What's the reason fo this?
It was more or less pegged to the right.What was the ammeter showing when this was happening?
Bob
