Dennis D 1929
My barn find 1929 Coupe has a strange issue. The amp meter seems to run "backward". With engine off, and key off, if you pull the lights on, it reads +10 amps. Engine running reads -5 to -10 amps. The gauge looks like a new replacement, so my guess is someone put it in backwards or set it up that way to accommodate a neg. grounded battery. Could I just fix the issue by taking the gauge out and switching the wires or just switch the battery back to neg. ground ? Are there any known issues to running the car with a neg. grounded battery ? My guess is they built the car as positive ground (from what I've been told) for a reason. Thanks for any comments.
