jkcrosson
I've read that in order to charge an optima battery with a standard charger, you must charge through a standard battery to "fool" the charger. ie charger hooked to a standard battery and then jumpered over to the optima. Does this battery need to be a 6 volt also or will a 12 volt work. I have charged straight to the optima battery for several hours and only show a 25% charge.
