California Travieso
When I put my Model A in the garage, I routinely turn off the gas valve and let It run until the gas in the carb is gone and the engine stops. Unfortunately, the last time I forgot to turn off the key. The next time I tried to start it the battery was completely dead.
I have an old Diehard 6/12 volt charger so I took the battery out Saturday and set in on charge. The charger automatically goes to 12 volt charge and I left it on. This morning I checked it and realized I didn't change the setting to 6 volts!
I got confused because have a modern 6/12 volt electronic battery tender that I can use on the Model A as well as my modern cars. It automatically detects whether the battery is 6 or 12 volts and sets it to the correct voltage.
I hope I didn't ruin the battery.
David Serrano
David Serrano
