Licensed to kill
So, I just purchased my first flathead 8 (has a crab shell dizzy) and am in the process of getting it running. It hasn't run in about 7 years, the guy said it ran good then lost spark and he just didn't get around to looking into it but suspected the points. I removed the dizzy cap and found that a bit of water had gotten in there and there was rust in the bottom of the cap. I have a new cap, condenser and points coming but am having issues getting the points out. My observations are this. each set of points have 2 screws that secure them to the body, one upper and one lower and the points pivot on a post that has a small bail wire keeping them from walking up the post. First, am I understanding this correctly?. If so, The points are seized on this post. If this is so, what is the tried and true method of getting them off without damaging anything?. BTW, I USED to think that Henry Ford was a pretty smart guy until I saw where he chose to locate the distributor on theses early flatheads. What a putz!.
