i agree Jack....with this intake new plugs the engine needs about 10 minuts to worm and run fine....but when is worm the response is good.....by the way i have the plug problem before i put this intake....thanks for the contribute!Not the best idea to be running a racing intake on the street. With no heat on the manifold you are just asking for drivability problems.
Try .043 jets and .71 power valves if you are running 2 97s.
Well...today i tested the coil and i try 2.3ohm on the primary and 8300 ohms on secondary , i have a 1.6ohm ballast in the circuit...meens that in this way i have a weak spark so i should change that ballast with one 0.7ohms of impedence for get 3ohms ? thinking that 8300 ohms on the secondary are a little low?!.......
Thanks for the help!now the parts are ordered..i need to wait since i live in Italy and some parts like carb parts need to be ordered in the states!my fuel pump is the stock 8ba ....in the carbs i have only metal screens so the air is free..i was thinking to start with no ballast since i have 2.3ohms in the primary coil.....i need to remove the ballast....by the way first thing i do is to put that ngk b4l plugs ....Yeah, tooo much fuel to air mix equals black sooty plugs ! Too much fuel, as stated, can be caused by many individual reasons and / or a combination of reasons. Start with the easy things first, i.e.- remove the filters and see if changes or no. Make sure hot spark is present at all times. If sooty, hotter plugs may be indicated to 'help' situation. Then leaner jets , if sooty plugs persist. Any air leaks in intake gasket will mess with mixture settings. Do not get lost in the weeds...first ! Do the simple things and eliminate those first..maybe find the answer therein. Do you have an electric fuel pump (with 2x2, I assume you do?). If so, what is pressure setting pounds !
BTW...this may seem elementary, BUT make a check list and check off 'things' as you go along and like a map will keep you on track and possibly lead to solution. If you are like some of us with older/fuzzy brain cell, maybe helpful![]()
A few things, I'd find a distributor machine and get the ignition sorted out on it and have caution with a hottor plug as they leave more heat in the engine and a flattie can have issues with heat.
You say that you had same problem before the navarro intake, did you have mutiple carbs then? I ask because you say at least som eof the carbs are recent - correct? so the problem might go back to a particular carb? For instance, if you originally had a single 97 on it and had overrich plugs and then you went with a navarro with an additional carb you purchased from the UK and still have the sam eproblem, then I'd be looking at the original carb - see what I mean?
When troubleshooting carbs I take them off the engine, raise them above the bench with 10" tall 5/16ths threaded rods (3 or 4 of them installed in the bolt holes) and then pump fuel into the carbs and see if they dribble under pressure. Fix each carb before reinstalling on the engine.
I tend to isolate, test and fix each componant away from the engine and then test/tune as an assembly after I know with certanty that each componant is working proper. If you have one carb with a dribble from powervalve, another carb with too low a float and an ignition with leaking vacuum pot you will go nuts trying to find just one thing to fix and the problem is like chaseing a ball of mercury.
