dwaynec
As can be seen from the attached photo my headlight reflectors are in somewhat less than fantastic shape. The bulbs work but no light reaches the road because of the very dull reflectors. So I ordered a set of reflectors and sockets from Bob Drake and am now trying to figure out how I change these things.
It looks to me like I have to remove the entire internal assembly from the bucket by disconnecting the headlight bullet connectors from the wiring harness and then removing the internal assembly by removing the adjuster screws and springs and then maneuvering everything out the front. Is that correct?
Once I get the reflectors out of the bucket is the actual reflector removed by just removing the bulbs or is there more to it?
Any suggestions you can give me would be gratefully appreciated.
Thanks,
Thanks,
