34Phae, more likely a stopped up vent tube or inoperable vented cap than a vapor lock. Check to make sure the pump is mounted near the tank and that the tank is well ventilated. It's very common in Fl that dirt dobbers stop up the vent system. Also, due to the natural "breathing" of the tank day and night as a result of temperature changes, dirt and moisture pass in and out of your tank. This phenomenom can eventually solidly stop up a vent over a period of 50 years.
The spring type clamps work well if you are using the correct size for the tube in question. They work well for the OEMs in billions of applications every day. I use them because they are a lot neater looking than the bulky worm screw type and more reliable. Easier to install and remove as well.
