And the reason for this is to do with the carb application. The float bowl vent was changed because the "fan wash" was affecting the float level.I think the 21-29 has the float bowl breather tube in the neck of the air horn/ The 91-99 does not. I would use a matched pair if possible either set would work ok. ken ct. Both carbs are the same except the way the float bowl vents.
