BottleRocket
I found four Champion X plugs that are used but in good condition. Probably not used for quite a few years. I want to clean them before using them. Is it best to clean them as a whole or disassemble and clean the parts?
I don't think X plugs are the correct size for a Model A? I think they're exclusively for the Model T.
I recently did a whole bunch of original 3X plugs. Using heat and kroil, there were only two I couldn't get apart. They were solidly rusted together. I plan to continue working on them, but am not holding my breath (though they do have good ceramic cores...). I did liberally use some "scotch brite" (but off-brand) buffing wheels on the ceramics as well as the bases, after I bead blasted the bases. I think they turned out quite well.
