I prefer the C-16C plugs over the W-16Y, that is the champion plug now available. I think that the C-16C is hotter but opinions will probably vary.Is a Champion C-16C plug too hot for a model A? I do not how too compare the heat rating with another plug.
Hotter down to colder thread:
http://www.fordbarn.com/forum/showthread.php?t=6458&highlight=spark+plug+hotter
I run the W18, they are hotter than the W16 Y, just like I have said for years. The heat range for the W16 Y is 6 the heat for theW18 is 7 . I believe the technical specs chart proves me right. Thanks Jim/TX for the web site, You have made my day. This puts all bull **** in its place.Very nice list, but the C-16C is not in there. Where does it fall? Between what and what?
I found a web site that had some technical specs, including heat range, for all currently available Champion plugs (so the C-16C is not included).
http://www.championsparkplugs.com/default.asp
Fill in the plug number in the Search box.
They cross reference the C-16C to a W16Y, but they also warn that they do not guarantee that this plug will be the same heat range, that you should use other application look-up options.
Jim
The C-16C and the C-4 are both discontinued and are not included in the Champion web site.Very nice list, but the C-16C is not in there. Where does it fall? Between what and what?
Jim
With the original side gap plug the spark is not hidden by that big ground electrode.
My experience with the W16Y has been the exact opposite and I don't consider it to be bull ****.
The Y designation means that the nose of the plug is projected to run hotter at lower RPM and this has been my experience with it. If the plug was W16 only then it would fall right in line, i.e., W18 is hotter than W16 which is hotter than W14 which is hotter than W10.
