I prefer the original distributor with a few simple mods, not the so called modern points. I run the wireless lower plate and the model B style points cam, or better still the new points cam that Bill Stipe makes. The model B distributors usually run too retarded and are more complicated. The B distributor is harder to time and you will really need to install the model B front timing cover.. The girls usually prefer the automatic advance. I installed a Mallory dual point distributor in the 31 coupe back in 94 and I haven't had to touch it since. My daughter now has the coupe and loves it. Electronic ignition is used on modern cars. I don't work on the modern cars so it only makes good sense to me to use something that I know how to fix if necessary. If you want hotter spark, I run the epoxy filled Pertronix flame thrower coil. I have the simplicity of the original distributor and points and probably hotter spark than electronic. I like using the spark lever.
