J johnmi Member Dec 18, 2015 #1 Installing new engine in car .The front of engine is off center 3/16 of a inch. What is best way to correct this problem Thanks John
2manycars Well-known member Dec 18, 2015 #2 Loosen the rear mounts and give it a yank. Retighten the rear mounts.
Gary WA Well-known member Dec 18, 2015 #4 Once you drive it,it'll probably move more than that! Happy Holidays!! Attachments Copyofsnow005-1.jpg 309.9 KB · Views: 25 02.jpg 76.3 KB · Views: 25
Chuck Sea/Tac Well-known member Dec 19, 2015 #5 was the old engine ok? Is the mount hole in the frame wore on one side? If previous posts don't solve the problem, there's a chance your frame is tweeked.
J johnmi Member Dec 19, 2015 #6 I loosened the rear mounts moved engine over where it belongs, retightened mounts gained 1/16 inch. Thanks John
