Roadster Rich
I have done a search of all the centering threads on the forum and there is good info available. I put Flathead Teds brake parts on my car almost two years ago. I did not center the front shoes top to bottom. As I adjust the brakes and move the adjuster in, I can definitely tell that I start to get uneven grabbing. Ie. the wheel turns freely for 180 degrees then rubs for the other 180. This occurs up until it grabs pretty tightly prior to locking. This has been with very little driving since the brake install. There is a slight pull to the left so I went back to adjusting with the 1/2 inch increments. Does this imply the front needs centering? If so I will get the measuring tool and go back to readjust.
