Kohnke Rebabbitting
Many a Model A cranks are set off center to the front, and Rear Main, ( Which is most important ) to keep a rear main from leaking, and also time gear mesh in front.
If the crank is off center, as much .010 thousandths, it will cause a leak, you can not fix, with out pouring the Babbitt again, and Align Bore again, this time centering between the Main bolt holes.
On the Model A , Ford used the Left hand rear Main Bolt , on the Drivers side of the car, and gaged ALL their machining Operations off that bolt hole.
The big problem with that, all Align Bore Machines have a Jig, with a set center distance, ( So you get the Gear Mesh Right ) that is used at each end of the block, but while the center distance can be right on, the crank centering, is often not.
An off center crank will leave a gap between the crank, and the Aluminum Seal, and you can't stop oil unless you close the gap.
Even if everything else is right, you have a leaker.
The Factory cranks were always centered, but very few new Babbitt jobs I have seen are.
I have all the jigs sets with my TA-15, A,B,V-8, and Fordson, and none I can use except the V-8, and that I have to use 1 to .005 thousandths of shims, depending on the motor to get the right center distance, but they will center the crank on the V-8"s.
Herm.
Herm.
