Center bearing
Andy
I built a 40 rear end for my 32. The torque tube was cut for the flange. I cut it again near the center bearig just to see it. It is different than ones offered by the parts venders. It appears to be a caged roller bearing and the replacements look like ball bearings. Anybody want it? I would send it for postage. I hate to see any of the old parts scraped if I can help it.
I have no way of checking it for wear. If anyone has the dia of the driveshaft, I would machine a part to check fit.
Andy: The OEM 40 center bearing is a special caged roller bearing encased in rubber with a hole for greasing. Over time the rubber will desintigrate, turning to mush. The original 40 OEM center bearing looks like the last photo. The driveshaft is not a tight fit in the bearing and easily slides in and out. Posting a photo of what you have would be helpful. Thanks for making your part available.
I took some pictures but the server is giving me problems. I have to email the pics to myself and then transfer to photos. It is not sending the pics back.
It looks like the posted pic. The rubber is soft but I can't pull the bearing out. I doubt if it is usable but I have no experience with them. It is not mushy.
Andy .....Try e-mailing the pic to me and I'll try to post it. DD
roundmotor@outlook.com
Thanks Coop.
I finally got it to work. For what it's worth, here they are. I cut some of the bearing off as I did not know how wide it was.
Usually the rubber that holds the bearing has turned to snot. i have a picture of a NOS bearing in the Std Coupe album and the KRW tool that installs it in my MISC photo album.
Mike's NOS Center Bearing & KR Wilson Installation Tool. You guys are in for a treat if you go to Mike's ALBUMS. He has some really cool stuff, and does some beautiful restoration work on his own cars. DD
picture.php
picture.php
Andy, That bearing rubber casing is too far gone. No longer usable.
Thanks for posting the pix.
I keep thinking there must be a way to re-encase the metal part of the OEM bearing
in a suitable material that will allow it to be reused. Perhaps the material that skate board wheels are made of or DELRIN.
Here's a thread that provides center bearing dimensions.
https://www.fordbarn.com/forum/showthread.php?t=233452&highlight=center+bearing+size
19Fordy,
With some work making the drawing, maybe it could be made with 3D printing. Just a thought. And thanks for your kind words Dick!
More confusion from me.
Since the consensus was that it was toast, I desided to investigate further. I cut the tube a couple of inches further away and tried to remove the bearing/rubber. Found an appropriate driver and wacked the bearing with my 8 lb sledge. I did seperate the inner tube from the torque tube. Nothing would dislodge the rubber from the inner tube or the bearing from the rubber. I had at it for quite a while. I finally dented the bearing cage and thru the mess away.
I am glad 32's don't use center brngs. I failed.
Will D. Thanks for posting that info. on how Mike repaired his center bearing. I wish I had seen it before I paid huge $$$ for a new OEM bearing in 2017. I still have the saved metal bearing. JIM
Here is the instructions from Skips replacement center bearing. G.M.
