pat in Santa Cruz
on a 30/31 pickup door, how does one get the tiny circular spring on the door latch rod ? I cannot get the spring over either end of the rod because of the tab that crosses the diameter on one side. I figure there must be some trick to doing it easily without bending the spring every which way.
The same problem would occur on a coupe or tudor.
Thanks again in advance
