supergnat
I think I caused my radiator to develop leaks.
Now, how do I fix them?
After reading the posts about the dangers of continuing to use the original steel fan blade I decided to replace mine. I had a few minor difficulties but completed the fan replacement. After taking the car out for 30 mile drive yesterday I discovered that I now have two leaks at the top of the radiator where the radiator support rods attach (see photo). How do I fix that? Can I solder around the mounting bracket using a Weller solder gun? Can I use a propane torch (which I doubt)? Should I use rosen core solder?
That is not all unfortunately. I had a stubborn leak at the base of the radiator hose where it connects to the water outlet pipe. I finally thought I fixed it by adding a second hose clamp just below the original one. I did try moving the original clamp to different locations but still had the leak until I added the second clamp. This morning I discovered the same hose is leaking again even with the two clamps. I cut the hose to remove it and investigate. The top of the pipe appears to have some damage (see photo). If I clean the outlet pipe up is it still usable? Could I have a 30-31 pipe on the car since it doesn’t appear to line-up correctly with the radiator inlet connection (see photo)? Bratton’s catalog says the pipe on the 28 should be 5 3/8 inches in height. Mine measures that if I measure from the top of the bolt flange to the top of the pipe; so maybe it is correct.
Any guidance you can provide would be appreciated.
Supergnat
Supergnat
