cast VS aluminum heads
55 dude
guys what are advantages of aluminum heads? where talking 24 stud. what is weight difference. thanks:D
There is a weight advantage in some cases. But, some aluminum heads weigh almost as much as stock, iron heads. Aluminum is much easier to re-configure, alter, and repair. Too, many people think they look better.
JWL, Regardless of looks, what can you say from all of your test results about the cooling differences between aluminum vs cast iron? Is there possibly something in your book that covers this? What about some of the other factors of comparison, or pros and cons, of Al vs CI? JM
To answer your question---It is very difficult to make direct comparisons between iron and aluminum Flathead heads simply because the chamber configurations would be VERY difficult to make identical matches of. Getting identical CR's would not tell the whole story.
Because the chamber surface area is enormous the Flathead engine would probably give up more power, when switching to aluminum from iron, than other engines.(everything being equal) Some power loss can be avoided by using modern coatings. However, iron heads can be coated too.
Aluminum heads will wear the head gasket much more than iron but this is not a factor with engines that only see a few thousand miles per year. I saw that Cometec has now introduced a MLS head gasket for some Flathead engines. This would seem to be the ultimate choice for using aluminum heads on a Flathead engine.
WOW, $148 each. Wonder if they will make them for the 49-53 Ford V-8.
"I saw that Cometec has now introduced a MLS head gasket for some Flathead engines. This would seem to be the ultimate choice for using aluminum heads on a Flathead engine."
