i have a 26 the motor was freshened up with new rings on the cast old cast pistons but i am still getting blow by when driving the block is stock i was thinking of taking the cylinders out ten or 20 and put new pistons in not shur weather to go alum or cast they tell me that the motor needs the wieght of the cast to run right and some say that alum are better less weight on the bearings witch way to go what do you run i want this to be a good driver mike
