Please Help.
I'm new to Model A's, converted from late 50's GM. I bought an oval speedo 1930 Coupe 6 months ago. Car was in good condition. The gentleman that passed took care of her. Brakes however were bad.
With help of my local club and Ford Barn we have rebuilt the brakes. And, I forked out $$$ and bought new rear assemblies from Randy Gross. (new backing plates, springs, shoes, pads, levers, bearings, CI drums, hubs, the whole works). Saving my money for front assemblies. Craftsmanship is excellent. Service after the sale has been great.
I have had help from my local club members, too. Even had a "service day" about my brakes at the club. And, that is where I need FordBarn's help.
The drums were not able to be installed. Too much friction. Called RG and he said sand down the pads a bit. We finally got drums installed. But they only freely spin 320 degrees. The stick with friction the last 40 degrees. RG said, "Drive the car. The pads are soft, they will wear in".
Well that was 2 months ago. RG has said he will "do whatever is necessary to make it right".
I have a bunch of senior model A'ers scratching their heads. The club prez has advised me to post this on FordBarn, read responses, take notes, and call RG. “We have never seen this with new assemblies”.
The rear brakes have been fully rebuilt. The brake pedal has no play, bushings new and reamed. Cross shaft has new bushings and has no play. All lever pins are snug. Clevis pin holes have been welded and redrilled and reamed to accept small pins. Brake rods are 50 1/2" and straight.
The problem is rear brakes cannot be adjusted and the high spot on turning the wheels persists as a problem.
In adjusting:
The rods are adjusted to the max where the threads of the rods require to be bottomed-out against the clevis pins. Otherwise, no braking action.
Using the correctly calibrated brake-pedal-tool the rears can be set to "snug", "tight", and "locked up" while on jack stands, as long as you stay away from the high spots on the hubs. But, on the road this does not manifest as good braking. The adjustment wedge has been advanced quite a lot.Per club members,m “more than should be needed”.
On the road adjusting requires so much adjusting of the wedge, the wheels will not freely turn with no pedal pressure.
Similar problem with emergency brakes.
The whole assemblies have been removed by club members, adjustment shafts measured and changed, pad thickness measured, adjustment wedges changed, etc.
Both rear assemblies have the same sticking problem for about the same ° of rotation. Axles are not bent. Bearings are new and greased. Shims not needed. Nut torqued to 125 ft-lbs. Anti Rattle springs and brake pedal return springs are new.
Please advise. Has anyone seen this with new assemblies?
Plan to call RG after I get a bivy of responses. My club and I are stumped.
Will
