Vic in E-TN
Last week I found a pile of old drums and hubs. I carefully pressed out the studs. I put the rear hubs on a cut off rear axle chucked in a 3 jaw chuck. The runout of the axle was 0.002.
#1 0.000, 0.000, +0.003, 0.010, 0.006
#2 0.000, +0.010, +0.010, 0.018, 0.005
I gave the second a few whacks with a hammer.
#2 0.000, -0.001, +0.003, +0.002, +0.006
My questions - What is the allowable rear hub runout prior to installing the new drum? Is the same number for the front drum?
Is it acceptable to true the hub by shaving a few thous off instead?
How can one mount the front hubs on to an old front spindle? I would use new races on the hubs and switch the bearings.
Thanks for your help.
Vic
Vic
