Y-Blockhead
I don't know how close you are to Montebello but Randy Gross is always an option 714-292-8660.
I am assuming your new shoes haven't been arced and that is the problem. Don't try and cut the drums to match the shoes or you will be throwing away valuable metal in the drums. You might try contacting Randy Gross and see if he can recommend a shop, melmodela@aol.com or call (714) 292-8660.Charlie Stephens ... in So Cal ... or anyone else ... ? It's sunny but chilly day at the top of the Cajon Pass.
Just got a set of front hub/drum assemblies and they measure out to the aforementioned 10.97ish diameter. Close ... but no cigar!
Same 'won't fit' over new shoes issues even though the supplier advertises they are turned after assembly. If they were? ... in my mind that should have meant that they are turned out to minimum 11.00" ... perhaps 11.002".
Anyone have a lead on a place within 30 - 40 miles that have the proper setup to turn Model A hub/drum assemblies?
RS
