They look good but I'll stick with my original Fenton's
Off shore knock off of the original Fenton design. The paper work is deceiving reads flatheads up to 1953 of course they will bolt to all years of the flathead. However they will not fit in early frames the Fenton casting was made to go in fat fender Fords so they will not fit in A and B frames the steering box is in the way unless a whole lot of modifications are made to the steering box and the back side of the left header in the area of the steering box.
Ronnieroadster
If I correctly understand what you are saying, neither these nor the original Fenton's will fit the "A" or "B" frames with stock steering. If that's true, then I think we should wait until the jury is in on these. I bought a set of stainless "Center-Dump" headers off eBay for $89.95. They fit perfectly and have performed flawlessly. The only problem is that they came with Metric fasteners.That was pretty easy to fix.
Prematurely judging these solely on their place of origin before knowing what they actually are could be a mistake.
I am using my original Fenton's in a 32 chassis with Vega steering. I have done several customer deuce chassis using this combination.
Try this link > https://www.hotrodhotline.com/butch...thie-cast-iron-3253-fordmerc-flathead-headersI looked thru Butch’s web site and catalog, but I couldn’t find the headers. The only cast headers on Speedway’s site were Fentons.
i have a 39 std with an 8ba. the drivers side wouldnt clear the steering box. had the flanges milled at an angle, perfect fit
