dan4banger
New member
I'm trying to assemble a pair of early rear end housing, pre 36, with a late ring gear carrier and notice the early housing carrier bearings and races are different than the late bearings and races. The new races I got are Timken brand number 68-4222, and these do not fit the axle housing as they are about .015 bigger in diameter and nearly .125 thicker. So none of this fits. Can I use the correct early bearings and races that fit the early housings and still use the late 38-48 ring gear carrier?
Somebody out there has got to have done this before me. HELP!! DanP
