Thanks Ron,
I will check the lower casting tomorrow to see if it has the drilled boss and pin.
But I am pretty sure that this one is not drilled and also I think this one has the cap and main jets offset making it a single venturi casting, unlike the double venturi ones that have the jets inline.
Off topic: If the early upper casting is paired with a single venturi lower casting what problems could I expect?
Are you looking at:
1. The 1994 version of page 1-8 with the table? ( Page 1-8 of 2011 version is sediment bowl info)
2. Or some where in the 2011 version?
3. Or Some other version of the Restoration Guidelines?
Thanks
