... i have a small leak between the intake manifold and carburetor base
If he uses 400 grit he will see his grand children with gray whiskers to their belly when he's done. That base is cast metal. Not aluminum. He's doing the base where it bolts to the intake,not the carb. body. This is a procedure that won't take more then a couple minutes. If you so desire you may do a few strokes with a finer paper to finish up. . Done this a hundred times and never destroyed a base. Not sure where 56y is located to direct where to purchase parts. As far as the jet plug remove it and make sure there is not a imperfection on the carb. or the screw. Feel with your finger nail if you need to. Napa or any larger auto store should be able to help otherwise Summit or Speedway.80 grit is way too course you wlll end up needing a new base if you try that.a much finer grit (400 -600) will suffice the advice given is good other than the 80 grit.being in europe it is not as easy to obtain rebuild kits that we can here good luck
what ever your 80 grit is different I have only done 80 at least and the cast iron on the ones I have done only needed the old gasket removed in some cases as the cast iron in the ones I have done were not warped you must have poorer cast iron than the ones I have seen.but hundreds?with the gaskets and spacer yours must have had a hell of a warp. my whiskers are down to mid chest.but back to his question about buying a kit.If he uses 400 grit he will see his grand children with gray whiskers to their belly when he's done. That base is cast metal. Not aluminum. He's doing the base where it bolts to the intake,not the carb. body. This is a procedure that won't take more then a couple minutes. If you so desire you may do a few strokes with a finer paper to finish up. . Done this a hundred times and never destroyed a base. Not sure where 56y is located to direct where to purchase parts. As far as the jet plug remove it and make sure there is not a imperfection on the carb. or the screw. Feel with your finger nail if you need to. Napa or any larger auto store should be able to help otherwise Summit or Speedway.
here is a link to one source I am not sure on shipping if you have a Napa over there it is another. there are a few good ones on this side of the Atlantic just not sure of shipping.be aware that most kits have parts for several different carburetors you must take care when assembling to use the right gaskets.I do not see where to add a link sorry .but the name of one company is called daytona parts or daytona carburetor a google search will bring them up.if as suggested you do not have a spacer on base then in the day they would sell a spacer that was made up of 3 base gaskets if any warpage this would easily take care of it.good luckwhat is the best refection kit for carburetor ? do you have a link where can i find it ?
here is a link to one source I am not sure on shipping if you have a Napa over there it is another. there are a few good ones on this side of the Atlantic just not sure of shipping.be aware that most kits have parts for several different carburetors you must take care when assembling to use the right gaskets.years ago you could buy a base gasket that was made of several single gaskets if slight warpage these would be more than ample to solve that problem I can not find a way to add link but the one I was going to suggest is called Daytona parts also Daytona carburetor.P.S they are called rebuild kits when searchingwhat is the best refection kit for carburetor ? do you have a link where can ifind it ?
