“The Mochi carburetor was manufactured in Argentina and marked “Industria Argentina” on the air inlet and “MOCHI” on the float bowl. The Restorer could find no information on the company or when these carbs were made. This Carburetor has a very rough exterior casting and is held together with two cap screws. The Mochi carb has a fuel inlet on the rear, probably to accommodate a Model B gas line, but could be adapted for the Model A. It is a very heavy carb at 4 lbs. The Mochi employs a single bleed air jet, similar to the Johnson Model JFA and Tillotson Model X carbs. The float is a unique design, not interchangeable with the Zenith. Since the Mochi uses a bleed air jet, it does not have a secondary well or idling jet. There are only two jets, the compensator jet in the bottom of the float bowl and a main jet. The Venturi is cast as part of the top half of the carb and so, is not removable. The Mochi is a simple design, employed with somewhat crude construction.”
