I agree with the comments about the float valve adjustment. If you look at a carb cut-a-way drawing, you will see that a 5/8 in. gas level puts the gas level right at the top of the cap and main jets. When I set the float level I try to increase this to 11/16 in. or just below 3/4 in. to prevent this "car on an uphill position" leakage. As long as the gas in the carb bowl always covers the Compensator jet, the lower bowl level will not be a problem. The other potential problem is coming up to stop signs. The throttle plate closes, gas sloshes forward in the bowl, the Secondary Well is nearly empty and there is no gas available for the Idle jet for a couple of seconds. It is a race to fill the Secondary Well through the Compensator before the car stalls. It is just the way Zenith designed this carb. Ed
