tiq,
What ford3 said. OMO start with 3.5 power valves and 47 or 48 jets. Be absolutely
positively sure the vac chamber is air tight with the bottom of the bowl and also
that there is a positive seal between the power valve and the bowl. Ad nausium,
I'll say again, vac leaks in the above areas will cause you fits.
Charlie ny
