A alanwoodieman Well-known member Sep 15, 2020 #2 how much carbon? you could use the old school solution. warm engine up and squirt water into the carb at about 1000 to 1500 rmp
drolston Well-known member Sep 16, 2020 #3 alanwoodieman said: how much carbon? you could use the old school solution. warm engine up and squirt water into the carb at about 1000 to 1500 rmp Click to expand... I use kerosene for that trick. Pour some in until the engine starts to sputter, then jazz the throttle to get it running again; repeat a dozen times.
aussie merc Well-known member Sep 16, 2020 #4 if its still running fill a spray with water/ metho solution [80/20] high idle 1200/1300 rpm and spray down carby about 1 quart should do the trick but depends on how much build up youve got
