kelly.ga
I just took my carb and fuel pump apart to overhaul both as suggested earlier from some of you guys and I have run into maybe a problem. The fuel pump was no problem but the carb has me wondering about a part listed on my parts sheet. If any of you guys have the parts sheet for a Holly AA-1 can you tell me if I need the part listed as number 42. It is a Needle-pump discharge. If I had one to start with I sure did not see it when I disassembled it, and I cannot find one in the parts I took off. Thanks a bunch.
