carb
Charlie,
I had a rebuilt Rochester on my 276 for awhile. It ran great but always had a bog when leaving the stop sign or going into passing gear. (C4) I was told that the secondaries are vacuum controlled and adjustments had to be made to the internal weights. That sounded quite wizardly to me at the time so went to a 390. Can you shed any light for me. I still have the Rochester plus 2 or 3 more.
Thanks in advance,
Fourdy
The Carter WCFB in my experience is more sophisticated than the early Rochester...
sort of like comparing the Ford 94 to a Stromberg. My reality is the Stromberg and the
Rochester are extremely forgiving. In most cases they'll swallow a load of dirty gas
and get you home. Vacuum leaks are tolerated without strangling the motor. 94s
and Carter WCFBs are great but more finicky and not as easy to dial in...that's the
way I see it.
To reply to Fordy....the Rochester I use is mounted in the same fashion as
it was intended when on the '52 Olds I removed it from. It is not a good idea to rotate
the carb so the secondaries are forward, this is done mostly to get the linkage on
the RH side to make it easier for hookup on early Fords...again this a no no because
the vac operated secondary 'flapper' is not happy working this way. I moved the
linkage from the left to the right to accomodate this quirk. Moving on... I did find
that there are good and not so good acc pumps and kits....I happily settled on
Classic Preservation Coalition kits as my choice ,absolutely world class. The bog you mentioned
could be a gasp for too little fuel or a choke for too much fuel. The culprit might
be an ineffective ball check in the acc pump well. FINALLY I purchased an air/fuel
meter from Summit and installed the o2 sensor in the RH head pipe and set the carb
using the readings on the dial. This required blocking the PV circuit and satisfying
the A/F requirements with the main and secondary jets. I have not touched the carb
in 4 years ,except once to remove a drowned fly that some how got into the bowl
and blocked a jet.
From my perspective performance is outrageously good and mpg is about 15,
284 cu in , 3:78's. No bog at all and in any gear if the pedal is mashed the response
is immediate. I dunno maybe I just got lucky.
Charlie ny
