kelly.ga
After my 47 v8 has set for several weeks it has started to stumble when I step on the gas. I recently went thru the carb and it had been running great. Then all of a sudden it started that old stumble/hesitating thing when you give it gas. I just replaced the accelerator pump but that didn.t help. It seems like when I'm under the hood pulling on the gas feed I can hear the carb or something else sucking air before it catches up. Also I can leave the choke pulled out just a tad and it works fine. Any ideas? Thanks
