Robert Legner
I have installed a pcv system that uses the wiper port but am not satisfied with this setup. I researched other systems and it seems that using vacuum from a different source may work better. The other source is vacuum from below the carburetor, but would not want to drill a hole in the intake manifold. I would like to keep the manifold untouched in that respect. There must be a plate that has an intake port on it that I can install between the carb and the intake manifold. I run a 239.4 8ba that is stock. Where can I purchase such a spacer plate if there is one available? Thank you in advance.
