Russell Reay
I have a Zenith 2, a rebuild kit, and the red book open on the bench. Two problems so far. The venturi is stuck very firmly into the top body. I have tried tapping the top of it, but there is too little gap to get a good contact with a drift. The book says heat may be needed to remove the venturi from the bottom. Will it harm the parts--esp the top body--by using heat on it? I am thinking propane torch, not acetylene. Two--the screwdriver slot on the main jet has been damaged by someone--probably unsuccessfully--trying to unscrew it. Now I cannot get enough purchase with a screwdriver to accomplish the task. It is now soaking in a bath of mineral spirits. Would heat help with this issue?
