It’s an NH. Got it off with a torch. Now I’ve got another issue. I’m trying to get everything apart, and I need to remove the two pins that hold the flaps in. I see that the pins are slotted, so that they fit through the flaps and then a wire goes in to hold the flaps to the pin and keep it all as one.
I’ve got the wire out but those pins in each flap are super stuck. I’ve tried the torch again; and that helped a little but they both are pretty stuck. I’ve got some carb cleaner and an ultrasonic bath but I’m not sure that will help get the pins out. I even tried drilling one of them out with no luck. Any ideas? Thank you!
