gmanrides
Hey guys I recently picked up a 31 coupe with a 59AB in it. It had run issues when I purchased it but due to the deal that was struck it did not concern me. So as Ol Ron say's I started putzin around with it. The engine has a set of Navarro heads with a Navarro 2x2 intake and a pair of 97's. The engine would start but idle was inconsistent and acceleration was poor, no power. I yanked the intake off and installed a stock single with a 94. She fired right up and rocked the little A when throttled, idled right at 450 rpm's. Keep in mind that the car is a fresh build and driven last year. The PO had the engine rebuilt and carbs rebuilt. I pulled the 97's apart and they both were filthy, looks like deteriorated rubber hose inside. after inspection my main concern is the pump wells and their condition at the bottom 1/4 of the wells. The have the 69 power valves and until my jet wrench gets here probably has 45 main jets. What is acceptable? Can they be repaired? Should I just start over with new one's? Thanks Gary
