dmaxweb
Three problems, three fixes, no more carb leak!
1. Replaced bad float valve...still leaking
2. Added a second float valve gasket to lower the float level...still intermittent leak
3. Took off again and found that the gasket was too wide at the front of the bowl and the inside edge was creating a 'lip' that would sometime catch the float. Trimed gasket flush with inside of casting...problem solved.
