Scottio57
1930 sport coupe. Zenith 1 carb. Been running great. One day on my way to work it would not idle, just died. Would restart and run fine just would not idle. The next day I noticed gas leaking from the adjustable needle and found the float valve would not shut off. I change the float valve from another running carburetor and it started leaking fuel from the small hole on the bottom of the intake throat at idle only. So I toke the float valve out and put it back in the other carb. and changed out the whole carb. Now it runs good and idles good but will not respond to adjustments. Adjustable needle and air mixture both shut off idles great. Open adjuster, no change. Open air mixture screw, no change. Both carbs are clean. I wonder why the original carb. Will run fine but leak gas from the throat only at idle and why the other carb. Will run fine but not take any adjustment?
