Billmc52
I was adjusting the idle mixture screw according to model-a.org instructions to turn screww clockwise until engine stalls and then out until it stalls then set between the two. My adjustment screw turned all the way in until it seated with no change in engine. It took about 1.5 turns out when it began to stall and I set it at about 3/4 turns out. My question, what is the reason there is no change in engine with screw turned all the way in, and what is solution? Scored screw and replacement? Or problem in carb at point where screw seats? Thanks for any info.
Bill
Bill
