steve fritz
What carb would you recommend for stock 302? I want to use a 4bbl intake from 70 Mustang. However I need to have the carb equipped with throttle hook-up so I can use the later model Ford AOD transmission. The AOD requires the TV cable hook-up. I don't think the stock autolite carb from the 60's-70's has this.
Does Holley or Edelbrock make a 4bbl carb for this application? I want to keep the CFM down cause the engine is stock, not hipo.
Thanks for any input from guys who have done this 302/AOD swap.
