Brobrian
I've been working on some fuel system related issues lately. I flushed the tank and took apart the petcock in an attempt to stop my Zenith carb from leaking out the air intake while it is parked with the gas is shut off.
Yet, even after removing the carb and checking to see that nothing was caught in the float valve, the carb still leaked. I then decided to check the float level by adding a washer to the float valve, thus dropping the float level significantly. Still leaked, so then I change out the carb to my old one. No leaks.
So, here's my thinking: Since the carb still leaks with nothing blocking the float valve and with the float level below spec, the float valve must be at fault. By the way, this carb is a new carb from Snyders, and has leaked since the day I got it.
I appreciate your time, gentlemen.
