Lyle
I won't to upgrade the 52 ford to a mercury intake. Using a later model. 2bbl carb. How will I need to setup the distributor vaccum advance? Or use no vaccum to the distributor and depend on the distributors internal weights for advance. Am I wrong thinking that the later carb has the vaccum pulled from below the ventura and the flathead carb is pulled from above the ventura. In other words will I need to change distributor to another. Other than stock? If so what will need to be used?? Thanks PS. Found another running flathead ****** and all.
