mhsprecher
I have a fairly new problem that I have just started to diagnose. When I turn on the lights, the car dies. It doesn't happen all the time, but most of the time. My car is a 6v with a Powermaster alternator. It charges at 6.5-7 volts when running. If I turn the lights off, it will start again easily. The fuse on the starter doesn't blow.
I looked at the light wiring and it looks okay. I took the light switch off at the bottom of the steering column. Everything looked okay. I cleaned it up and reinstalled it. It is a repro light switch, probably at least 20 years old. I also loosened and retightened the ground. I have a second ground to the transmission, too.
I took a look at the headlights. If I take one bulb out of either side, the car doesn't die when I switch on the lights. Sometimes if I turn the lights on, the ammeter registers a discharge and the alternator reads it is charging at 5v and the engine misses. It will then die sometimes.
One thought is that I need a ground in the headlights, but I have not had this problem until last month. I am a bit stymied at this point. Any ideas?
