billybronco1
Key off 6 volts both sides of the coil.
Key on points shorted six volts on neg side of coil and .65 on the pos side.
If "key off" you have 6V on both sides of the coil, then either the ignition switch is bad and still making contact in the off position, in which case you would not be able to turn the car off with the key, OR (hopefully) your have a typo in your post and you really meant "Key ON 6 volts both sides of the coil".
Yep 6 volts on both sides of the coil with key off even the switch disconnected.
Okay guys something no one seemed to think of is a bad condenser - all fixed this was a good learning experience - thanks.
The bottom plate has a short multistrand very flexible wire with a flag terminal that is fastened to the bottom of the points pivot/mounting stud. You must tighten the nut then bend the flag terminal against the nut. If you don't bend the terminal up against the nut then it might stick out enough to touch the spring and short to ground.
Don't get fooled, a volt meter from ground to the switch side of the coil should show 6V since the meter itself completes the circuit.
