make sure to scrape any paint off where your ground is bolted to the eng. groung batt. to eng. , eng. to frame, suggest you do this next to the starter, and then ground the body to the frame. you can not have to many good grounds in a six volt system, and like what was previous stated the correct heavy diameter cables are a must. if all this is correct and you have a fully charged good batt. ( battery can have 12 volts and still not pass a load test ) I would say that your bearing clearances may be on the tight side.
