It ran fine for awhile... your problem is somewhere in wiring as you must have moved a ton of stuff to open the timing cover.....bad ground, shorted wire...are you using a fuse, if not you may have a direct short in old wiring you moved to access timing cover...if no fuse put one in see if it blows. You don't have a timing problem...in my often mistaken but cocky opinion.
